Hi Notch folks!
I’m developing an interactive installation and I need to save several still images and assign a specific name for each ‘capture’.
I would love to set the filename for the captured image with a specific string (probably from osc)…using “Capture Image File” node I can’t connect any node to the Filename Attribute.
Is there a way to already achieve this?
Any hints?
Thanks in advance
Best regards,
Alberto
