Would be great to Copy/Paste nodes between different Notch Instances. For simple setups this would be quicker and easier than scene merging…
Notch already supports copy and paste of nodes between instances. See http://manual.notch.one/0.9.23/en/topic/introduction-keyboard-shortcuts (Copy to Clipboard/Paste from Clipboard).
Ah, great to know! Wouldn’t it be easier to feature the function in the Right Click Menu?
And why not using the standard Copy/Paste hotkeys? Would be even more intuitive… Thank you!
There is actually a reason its not just Ctrl+C/Ctrl+v - the way copy paste works in windows doesn’t give access to all the right data a node contains, and it would be pointless to copy paste a node without the properties matching.
Sticking it in the right click menu sounds reasonable enough, but I usually find myself using the Ctrl+U/Ctrl+I short cuts most of the time anyway.
Interesting, I thought Copy&Paste is fully controlled by the developer and therefore you can copy all the meta data you want.
I understand that hot keys are easier, but the Right Click Menu would help people (like me) that haven’t heard about this functionality
Thanks Ryan!
It’s also worth pointing out that with a Learning license you are limited to copying 3 nodes to the clipboard using Ctrl+U. With a Base/Pro license, that limitation is removed.
Regards,
Tom
@rs2minds Thank you for posting this. I had previously thought this was impossible for the same reason you did – it’s currently, er, a tad bit unintuitive.
Perhaps 10-bit can do a survey/poll on the Notch Facebook group (or newsletter, or anything) to see how many users know about this functionality, as well as other Notch features in general. Perhaps I am wrong and most already know about it - if so, hooray! If not, seems like some of the changes we’re suggesting here would be very helpful to the community, especially for the next big release.
Thanks all!
There’s no point in doing a survey because the functionality will not change due to the reasons @ryan.barth pointed out above. We do however do a lot to point this out across the manual, keyboard shortcuts PDF and elsewhere, but we can always do better.
As for Notch features in general, we have a campaign coming up which is going to showcase a bunch of features that’s been in the software since even before the very first version that a lot of people are unaware of (like live network editing for example), so keep your eyes peeled on “the socials” for that one.
