Hi!
Cant drag&drop files to resources panel. Try to run app with administrator rules, still not works.
Is the any solution for this issue?
What type of files are you trying to drag and drop? And which way? (to or from the resource panel)
I am trying to drag & drop c4d, fbx, tiff, jpg or wav from windows explorer to resource panel.
Maybe I need assign some extra options when I boot the Notch? Any idea why I can’t drag&droop files to notch resource panel?
This was resolved via our official support channel. The solution was to disable the “Run as an administrator” checkbox on the application executable.
Cheers,
Tom
