Change colour input on colour ramp or blend 2 colRamps
Hi NotchBuddies - I´m trying to switch colours in a colour ramp connected to a fft texture. I would like to change one of the colours (on demand) , but I can`t find a way to change the input colours to have two colour inputs. is there a way maybe to blend to colour ramps? everytime I try to use a combination method , the fft node does not accept it as a ramp anymore.
any solutions? that would be fantastic :sunny:
Hi,
You can use the select input node with 2 fft textures (with 2 coulour ramp), or use envelope modifier for colour RGB colour in “colour ramp”.
Regards,
Adrien
Heyiiii Adrien! Thank you so much for the quick help! the second version is neat :grinning: :star_struck:
