Blob Tracker help
Hello,
I am having a difficult time experimenting with the blob tracker as the documentation on this node is quite vague. Have there been any recent updates with the implementation of this node? I am attempting to follow the manual without much success. Thank you
Hi there,
There were a few issues with the blob tracker node in 0.9.21rc30, which we have now fixed.
I suggest opening a support issue with us so we can provide you with an updated build.
Regards,
Tom
Hi Thomas,
How would I go about that? I dont see it mentioned in the Manual. Do I just email info@notch.one and ask for a link to an updated build?
Thank you
Hi,
Please see https://www.notch.one/support/contact-us/
Regards,
Tom
Is there any update on the documentation for the blob tracker coming soon? Doesn’t say that much at the moment, just that it needs a prepared image input.
The manual is going through a big rewrite currently as a part of 1.0. The Blob Tracker will be included in this process but I can’t provide an ETA on this - I’d recommend keeping an ear to the ground.
