Hello,
I have this wired banding shadow glitch. Somebody have any idea why?
Thanks.
Hello,
Thanks.
Ill check this out maybe be a normal map issue. Not sure. or increasing your shadow map size.
Hey,
Set your camera near and far clips to 0.1 and 1000 to fix this.
When you stretch those too far apart you are also stretching the accuracy of your 3d space, so its always better to keep those as tight as your scene allows.
Chears,
-Jani
Great! Jani !
I don’t have any idea about this issue with the camera.
Thanks a lot!
Edgar
