Hi there!
What is the proper method to speed up image sequence or pre-rendered video file based on the audio level? I managed to do the trick - but I couldn’t inject the optical flow node into the graph - in order to have properly calculated motion-vector based in-between-frames for the speed-ups and slow-downs (according to the audio-level of the imported sound-file). Is there a global-switch for calculating in-between frames like it was in aftereffects? Or is there an alternate method to build this feature?
Many thanks in advance!
Cheers,
Ivo
audio_level_to_video_speed_with_oF|690x436
