Activate checkbox in java
Hi,
I try to activate deactivate a checkbox with javascript node.
i can control float and int value withour problem.
i read on the documentation that Checkbox work with int = ‘‘Checkboxes are integer properties.’’
Is it because there is no K ‘‘keyable’’ option next to the parameters ?
I want to change the Clear Every Frame in the Root Field with this :
layer = Document.FindLayer(“LayerName”);
node = layer.FindNode(“Field Root”);
node.SetInt(“Attributes.Clean Every Frame”, 1);
Thx for your Help !
Fred
It looks like there’s a typo in your code :slight_smile: The property is called “Clear Every Frame”.
node.SetInt(“Attributes.Clear Every Frame”, 1);
Ahah my bad.
Time to learn to read ^^
Is their is some function OnKeyRelease(key) somewhere ?
It can be helpfull for momentary action.
Thx Ryan !
