Just wondering what Quicktime codecs I can use?
Simon
Simon
Hi Simon. Quicktime Codecs fall into two categories:
Our Native support is expanding as time goes by, but you can cover all the other codecs with the Quicktime framework (which works pretty seamlessly) in the meantime.
The reason we are moving to Native codec support, is that Apple’s support of their Quicktime framework on Windows is dwindling, only 32bit, occasionally struggles to handle very large resolutions well.
