Notch Block & Touchdesigner - Kinect Azure
Hello,
I’m trying to playback a Notch Block that uses Kinect Azure in Touchdesigner, when “Apply Body Masking” property is exposed it seems to have no effect on TD. It automatically detects the whole camera view and does not apply the masking when changing the value. (In Notch it is a checkbox/boolean, in TD it loads it as integer so I use 1 or 0 ) .
When is exported as standalone app the Body Masking works fine .
Has anyone faced a similar situation, any idea what could be happening?
Thank you.
