Is it me or are there no drag handles in the PLE?
Same Question…just got PLE…NO HANDLES! Seems impossible to use tool without handles, this must be a bug!!! Can anyone confirm? Is there some weird workaround?
Hi there,
Make sure that the handles button is activated on the center toolbar. It’s these buttons you’re looking for:
Alternatively, use these menu options from the View menu:
Hope that helps.
Regards,
Tom
yup, had those clicked, it was the classic noob “its not paused” issue for me:)
thanks!
