Newbie here. Please bear with me
I know about the MIDI modifier and the Recorded Value Parameter but I need to use data from a .MID file (many tracks, channels and CCs) to control different parameters of particle animations using Notch. I need to access the articulations (CCs) and such, not just the audio data from the wav file.
Iโm on Win10 (PC) so I think that loopMIDI or similar would do the job but looking for a way to directly read the MIDI file inside of Notch.
The file is from a composer and I am asked to create visuals based on MIDI (not audio) to match.
Thanks for any help!!
