Hey there. I’m a pipeline dev my work and I’ve an issue with an artist trying to save or render files to a network drive. He has no problem saving locally, and then copying the file over, but this is not a great workflow.
If I open this file with a learning license of Notch I am able to save it to the network, but then is is locked to be opened with learning version of notch, which is not desirable.
From what I can tell:
- Not a permission issue. We’re able to save and render to the same place with other software.
- Not a space issue. we have TB free.
- I saw that release 9.23.180 there’s a bug fix note: * [UI] Fixed a bug when checking the destination drive for the amount of free disk space. The artists are using 9.23.200 so its not that bug.
- Checked all source files paths and preference paths for special characters… none detected.
The error message reads:
Demolition FX
Error OnSaveDocument. There is not enough drive space available on the destination location.
I’d include the file but as a new user it won’t let me. The file is only 8 mb, pretty basic file.
Any suggestions
