Hi there… how can one create a radial gradient. I am using Colour Ramp > Material > Shape 3D (circle)
In the Colour Ramp node I only see linear gradient. Is there a workaround for radial gradients as shown in the attached reference picture?
Hey Dean - I believe there is a gradient node where you can switch between several modes such as linear, radial, reflected etc.
Thanks a ton Mogens… used Gradient under Generators… was stuck using Gradient 2D linked to a color ramp which was the issue I see. Cheers!
