Hi everyone,
Is there a way to connect a new node to another node within a group, without having to ungroup, connect and regroup?
Thank you very much
Hi everyone,
Thank you very much
Hello Eduardo,
Hover over the group line till it is marked up yellow then hold down alt and double click on the line, you will get a connection quad, there you can plug in external nodes to a group.
If you click on the quad and hold shift you will be able to reposition the quad anywhere you want on the group boarder.
Best,
Armin
This is a good workaround, but would be great to be able to add nodes inside an existing group, maybe this a FR.
Thanks!
Hi Armin,
Thank you very much for your answer.
I do agree with Alex1 and it’s more related with the question I made.
Best,
Eduardo
or, you can select group and nodes you want to add and then right click [group selected nodes], and boom, you have your nodes inside group.
