Transform Array for Javascript
The Transform Array documentation mentions using it’s arrays inside of a Javascript Node- what’s the method for doing this?
This was solved a while back via support, so just following up here.
You can find the relevant JavaScript functions in the manual at the following places:
Getters:
Setters:
