Hi everyone,
I am trying to locate a sample project from the Notch manual but I can’t find it anywhere? Attaching a screen:
Thanks!
Best,
Arty
bent
2
Hi Arty,
This sample ships with Notch. If you start a new project, you’ll find it in the pop-up screen under “Samples”, cheers!
