Project image onto model
Hi Guys,
How does the project image node work ?
i would like to apply a video texture to a 3d model, the model is basically a room with 4 walls,
and i need to control where the projected texture falls and restrict it to certain surfaces
I’ve managed to follow the instruction and apply a texture, but i cant control where the texture falls very well
Thanks in advance for any guidance on this,
Percy
Sounds like you want to use either the decal node, or just use a light using a texture as a projection image.
there’s an example of the decal node on its manual page - I think this is closer to what you want to achieve.
