Hi everybody! I’m doing an project which is an historical timeline with sereval text paragraph. Is there a way to force a carriage return in a text object? sure there is the “fit ti box” option, but it ain’t precise enough. The other way would be to go with one text object per line for each paragraph but I’d rather not go that way unless I really have to.
So is it possible? If a carriage return isn’t doable, that’s definitely a feature I’d like to see in a future update!
thanks
If you press the S icon to the right of a text string parameter, a small text editing window will appear. In there, just hit Shift + Enter every time you want to make a new line.
Thanks Ryan! that will definitely be useful
