ArtNet Transport Control Universe
How do you set the universe of the ArtNet Transport Control?
You can’t manually set the transport control universe specifically, but you can use the global offset to push the universe up. if you enter a multiple of 512, it will drop into the next universe up, but it will offset all the other Artnet universes too.
Oh that makes sense. I will give that a try.
